Hosted by Jim Starkweather
how to apply oil canning effects
Panzer_Modeler
Posted: Tuesday, August 25, 2020 - 04:15 PM UTC
Im planning on building the 1/72 Revell Gato and I was wondering if anyone has any good techniques on how to apply oil canning effect on ship models? I feel like it would improve the general appearance of the sub so any ideas appreciated!
russamotto
Posted: Tuesday, August 25, 2020 - 11:48 PM UTC
Years ago there was a blog build of the 1/144 Fletcher. The modeler had marked off each panel on the hull and was using a curved blade to carefully scrape out the plastic to create an indentation. He never did finish the build. That is the only instance I can think of that I have seen.
EHAM0624
Noord-Holland, Netherlands
KitMaker: 200 posts
KitMaker: 200 posts
Posted: Wednesday, August 26, 2020 - 01:20 AM UTC
Yes as Russ mention a scalpel will do the trick not come practish but most certainly used for stressed aircraft skin 1/48, 1/32 scale (it's a lot of work but the effort well worth) i guess for the 1/72 boat it will just work fine
Biggles2
Posted: Wednesday, August 26, 2020 - 01:28 AM UTC
You can simulate it with a LOT of masking, and a LOT of very careful airbrushing...ie; lots of practice needed.
mat
Posted: Wednesday, August 26, 2020 - 01:29 AM UTC
I know of 2 techniques,
the one mentioned by Russ and you have shading with paint, but that only works nicely for 1:700 scale models.
the problem with the Revell Gato is that is misses a lot of rivet detail on the hull which is more of a problem than the lack of oil canning in my opinion. I used the Eduard set to resolve that problem.
d6mst0
Posted: Wednesday, August 26, 2020 - 01:49 AM UTC
I seen several demos on you-tube. One video was with a rotary tool.
Grauwolf
Posted: Wednesday, August 26, 2020 - 02:37 AM UTC
Here is the thread on how it was done on the Fletcher:
https://modelshipwrights.kitmaker.net/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=134929&page=1
Panzer_Modeler
Posted: Thursday, August 27, 2020 - 07:16 AM UTC
Thanks y'all this is really helpful! Mat thank you for pointing out the lack of rivets, to combat this I bought a HO scale rivet decal set. ( I know not 1/72 but close enough) I going to add the oil canning because im going to weather the s*** out of this model, and I think it would make it look more interesting.
Grauwolf
Posted: Thursday, August 27, 2020 - 01:28 PM UTC
Ezra, if you are going to do all that extra work, you should consider adding all
the missing flooding vents at the bottom of the hull.
Here is a link to templates you can buy to guide you in adding these missing details.
http://nautilusmodels.com/72-701.htm
Panzer_Modeler
Posted: Thursday, August 27, 2020 - 01:36 PM UTC
Oh yah Joe i saw someone do that on a 1/144 Gato and I thought it looked amazing so its a definite! ( Im doing the platinum edition so im going full out with the details!) Ezra, if you are going to do all that extra work, you should consider adding all
