It's been awhile posting on the shipwrights website. Having built the PT 596 I found the Italeri Schnellboot is by far more of a challenge due to it's sheer size and complexity for detailing.
This time is going to be different as the Schnellboot will be ploughing through the seas with guns in action.
I have a dire need to create and work with water and nothing better than to start with the Schnellboot. There is zero knowledge of working with water. I have the AK water and snow diorama book and will use that as a template to when I get to that stage.
Without further boring everyone, here are the progress shots of work commenced.
To achieve the right effect I have had a base made up as close as to the size of the box.
A combination of Azimut and Italeri Schnellboot crews will be used for the Schnellboot. The Italeri crew will have the heads and hands corrected to make up the balance of figures to be used.
Metal barrels from Master Model will be used in all the mounts. A definite must to enhance the guns.
The Eduard big Ed set is a must for enhancing IN some or most of the details. You can get away with not using it. I found in areas for the guns and some other areas on the boat the etch will stand out.
Here is the sample images of a 2 part resin which will be used for the sea. Will experiment first with a small batch before hand to see how it handles.
One of the first plans of attack was to rectify the hole opening for the 2cm on the bow. I received a new gun mount template from Abdin who completed a super detailed Schnellboot. Special thanks go out to Abdin for the template because the sample he provided saved me a huge amount of work.
Abdin's build can be found here.
http://planetarmor.com/forums/showthread.php?t=7214
Abdin did a fantastic job on the schnellboot and I am using his build as a sort of reference point as I found there are very few boats around the web that have this extensive detailing.
Rest assured I will not be detailing this boat to the extent Abdin has done.
Most of the boat is built with parts being store in plastic containers away from dust.
Just completed the twin 2cm mount with the parts in sub sections for painting and detailing.
The Azimut gun crew have been used with Alpine and Hornet head conversions. The figure with the Hornet head will have his arm re positioned to fit on the crank handle at a later date.
Moving forward to commence the 37mm gun. There is a lot of work in this area to have the figures posed sitting on the gun in firing mode.
Here are the 2cm images
More to follow shortly...
Michael
