A few kits on the go.
KitMaker: 8,579 posts
IPMS-UK KitMaker Branch: 2,023 posts
Posted: Monday, April 24, 2017 - 11:44 AM UTC
I have a few models closing in on the painting stages. First up painting the interior colour on the canopies.
Airfix 1/48 Spitfire MkI
Airfix 1/48 Hurricane MkI
Airfix 1/48 BP DEfiant
Tamiya 1/48 Bf109E-3
Hasegawa 1/32 Ki-61
GazzaS
#424
KitMaker: 4,481 posts
Posted: Monday, April 24, 2017 - 12:11 PM UTC
Nice looking work, Mal.
As a person always trying to improve on canopy results, I'm a bit curious about the blobs on each mask and panel.
Gaz
AussieReg
AUTOMODELER
#007
Victoria, Australia
KitMaker: 7,520 posts
IPMS-UK KitMaker Branch: 20 posts
Posted: Monday, April 24, 2017 - 01:58 PM UTC
Likewise, I'm curious Mal, and how about a pic or 2 of the Tiger?
Cheers, D
KitMaker: 607 posts
IPMS-UK KitMaker Branch: 446 posts
Posted: Tuesday, April 25, 2017 - 11:19 AM UTC
Looking good Mal.
I will of course be following these
Posted: Tuesday, April 25, 2017 - 11:47 AM UTC
Gaz
Cheers, D
I have masked the canopies using Parafilm M. The blobs are waste bits of Parafilm pressed onto the masking pieces to aid removal of the masking. Easy to get hold of and pulls up the masking when the time comes
I actually completely forgot about the Tiger and at least one other model. I'll post pics later
Bigskip
KitMaker: 2,482 posts
IPMS-UK KitMaker Branch: 975 posts
Posted: Tuesday, April 25, 2017 - 06:28 PM UTC
You obviously "get on" with parafilm, any tips, it's never worked properly for me, i'm a tamiya tape kind of guy.
Posted: Wednesday, April 26, 2017 - 03:53 PM UTC
Yep I'll post a SBS, I find it to be the easiest way of masking canopies but you do need to understand a few things when using it
Posted: Thursday, June 22, 2017 - 11:47 AM UTC
Just starting with the painting.
I primer coat using white, then pre-shade using a "complimentary colour" to the camouflage. In the case of the 3 RAF aircraft, Spitfire, Hurricane and BP Defiant, I have used RLM 70 Blackgreen. For the Bf109 I have used RAF roundel blue, and dark earth, for the yellow nose areas.
I sort of cocked up the method when applying the under surface colour (Sky) on the RAF machines in that I should have gone over the RLM 70 pre-shading first, then paint along side it, before several coats that cover everything. The slight hiccup doesn't matter though as I painted over the RLM 70 second. The trick, for me anyway, is that when you think it is close to being the right amount of paint stop. Come back the following day and you will, more than likely, see that it wasn't quite enough so add more, carefully and stop and come back again, if necessary. The Bf109 was done in the same way but I remembered what I was supposed to be doing but, like I said, it didn't really make any difference
Just to explain a little more, after painting over the pre-shading then along side it spray a little wider covering both areas. The idea is to leave the white primer coat unpainted in the centre of panels so that when you apply the "blending coat" (wider pattern and overall coats), the darker pre-shaded areas get a bit more coverage and the lighter areas show through the paint to make those areas just a tad lighter. ISH!
BP Defiant:
Spitfire:
Hurricane:
Bf109E-3:
